VMWare 7.0 Installation problem on Vista
Asked By 7060 points N/A Posted on -
I am trying to install VM 7.0 on my personal Intel machine having 32 bit Window Vista operating system. Everytime I am getting an error msg that "VMWARE INSTALLER STOPPED WORKING, WINDOW IS CHECKING THE SOLUTION" Can somebody suggest me how to solve this problem?
Answered By 0 points N/A #84165
Hello Dear,
                    VM doesn't create any problem on 32 or 64 bit windows. There can be following problems :
1. Maybe the setup of VM 7.0 is corrupted, because of that you are not able to install it. Try to download fresh copy of VM 7.0 or     try to download and install the latest edition which is (VM 8.0.3 build-703057).
2. If you have older version of VM on your pc, then uninstall it properly and then install VM 7.0
3. If the above methods are ok then there is definitely some problem in windows and you need to re install your windows.
Hope that this will be helpful for your problem
All the best.
