I have been unable to install vFabric Data Director as it fails miserably.I get the below mentioned error.To me it seems that there is a communication lapse between the Management Server and vCenter or the ESXi Hosts.
"Cannot setup vCenter network. Cannot login to vCenter Server."
Has anyone come across this issue before?
VMWare: Cannot setup vCenter network
The problem here is either a connection-related issue or a problem with the program itself. If this is new installation, try closing the application, restart your computer then try it again. See if there is a change after rebooting. The next thing to check is your computer’s network connection. Since the program requires an internet connection, you should check the network cable at the back of the CPU if it is connected and attached properly to the port. You should also check if your network is not experiencing heavy web traffic that reduces the connection’s speed. If you are trying to use the program during peak hours then maybe you should try it after a couple of hours or during off-peak hours to have a better connection.
You may also try reinstalling the application to free your system from any corrupted files that are probably affecting the whole process. Uninstall the application then restart your computer when asked. After booting, check your machine for any possible errors. Use a disk utility application to check the system. Install the program again then check if this fixes the problem.
