I got a problem when I tried to install sisulizer 3.0.336 on a Windows 7 running in VMware Fusion 5 for MAC OSX. When I click on the on the installation file then I received the following error message. I would really appreciate ant help.
Thanks in advance.
Exception ERegistryException in moduleSisu_3_0_336.exe at 00031BE4.
Failed to get data for'ProxyEnable'.
VMware Fusion 5 application error on win 7
Hi Donald,
               The error is caused by a registry key missing, changing registry information may be risky at it may affect other software, I also found a website where you can send the logs on the error and then they will reply back with a fix as the issue can be caused by multiple errors. In the mean time you can try to run a repair on the program to see if it can rebuild any system files that got corrupted it would be best also if you will use the installer so that it can copy the files missing directly from the installer package.
