VMware Fusion cannot be installed on Mac
I am attempting to install VMware on Mac Operating System. My requirements meet to install VMware the why am I getting this annoying error message? Do you have any idea or resolution to fix this issue?
Thanks in advance.
VMware Fusion can’t be installed on this computer.
Sorry, VMware Fusion can only be installed on Macs with Intel processors.
Answered By points N/A #182016
Hello Terrell,
VMware is a popular virtual PC software. It is also available on Mac. But unfortunately, it is not available on your PC.
VMware requires Intel processors to function properly. As you have got other processor other processor or AMD, it is not supported. So you are unable to install it.
You should change your processor in order to use it. Otherwise, it might not be available for you.
Also, VMware Fusion is only available for x64 on Mac.
Go to Apple menu >> About this Mac >> More Info >> Software
If you find this line, it means you have got 32-bit (x86) kernel.
64-bit Kernel and Extensions: No
Upgrade your Mac to 64-bit (x64) to install VMware Fusion.
