VMware v center converter agent deployment error
I received the following error message when I was trying to convert a Remote machine using v Center Converter agent deployment. What should I do now? I need your suggestion to resolve this issue as soon as possible. Any help would be appreciated. Thanks.
VMware vCenter Converter Agent Deployment
VMware vCenter Converter agent needs to be temporarily installed on the remote source machine 172.20.2.2.
Uninstall VMware vCentre Converter agent
Automatically uninstall the files when import succeeds
I will manually uninstall the files later
