VMware Workstation – Looking for Solution
20 points
Posted on - 08/14/2012
I find a problem to set up OS in Virtual machine.
I attach some screenshot her.
1. Usual Settings
2. When I try to set up, this appears
Windows XP Professional – VMware Workstation
Software virtualization is incompatible with long mode
on this platform. Disabling long mode. Without long
mode support, the virtual machine will not be able to
run 64bit code. For more details see
https://www.vmware.com/support.html.
Do not show this hint again
                             OK
Unable to process CD-ROM device 'D:':The system cannot find the path specified
Please ensure that your configuration is correct.
Virtual device ide1:0 will start disconnected.
I need to solve these. Please help me and give a solution.
Thanks a lot.
