VOB2MPG for DVDs the other memory is corrupt
I use VOB2MPG for DVDs. When I tried to burn one I received this error (please see image).
Why does the window message mean, especially on the part when it says “the other memory is corrupt”?
How do I fix this?
Any reply would be appreciated.
Thank you.
VOB2MPG – DVD Player
Could not get interfaces
Attempted to read or write protected memory. This is often an indication that other memory is corrupt.
Answered By 5 points N/A #176737
Your VOB2MPG might not be correctly installed.
However, try this alternative fix first.
On the Options menu, select remove unreferenced and blank cells. This will remove unreferenced DVD materials (e.g. IFO).
Review misconfigured PGC LBA pointers then fix it. This will remap a cell if the reference is pointing to a non-existing/ corrupted file.
Select in- place (no backup).
Reopen your VOB file then burn again.
