Vodafone Mobile Broadband error during the installation
This error appears during the install of my Vodafone Mobile Broadband Lite driver for my PC. I had to reinstall the driver because I have updated my Windows 7 and I didn’t find the application installed. Any solution ? Why I have this error ?
Thanks !
Vodafone Mobile Broadband Lite – InstallShield
1152: Errore durante l’estrazione di C:DOCUMENTE~1FRANCE~1IMPOST~1Tempnella posizione temporanea
OK
Answered By 0 points N/A #179910
Hi Christopher,
I have read your problem and it seems to me that you are facing an incompatibility issue here. In order to solve the problem:
1. Uninstall the previously installed software and restart. If the software is not found in the installation directory, go to the next step.
2. Delete the installation folder from the Program files under System.
3. Download the latest driver software compatible with your Windows 7.
4. Install the driver following the procedure.
Hopefully, this time your driver will be installed properly.
