Ian M Tyner
10 points
Posted on - 05/21/2014
This started ever since I download the trial version of an app .I’ve not accepted the Voice Command agreement. Whenever I accidentally activate it by pressing the home key the wrong way, I select Decline. What does this error message actually mean? I can I get rid of it ?
Thank you !
Voice command
An unexpected server error occurred. Please try again.
OK
Voice command An unexpected server error occurred
I’m not sure if that’s really the problem because the error is referring to the server. The problem here is that you did not mention the name of the app so we can better check it. In this case, if the error keeps happening again and again every time you use it, try reinstalling it if you still have the installer. Also, when installing the app again on your phone, make sure to accept all agreements that prompt you.
After reinstalling the application, make sure your handset is still connected to the internet when activating the app because the program needs to contact its server for the activation process. You won’t be able to activate the app if your phone is not online. Also, try updating the app or download a much newer version.
Installing a much newer version or the latest version will give you better performance and stability because previous bugs were already fixed.
