VOIP Sound Quality for Mobile Phones
Hello!
I’m planning to buy a mobile phone that has VoIP applications, is there anyone here experienced about its sound quality?
Does it sound good on mobile phones?
Hello!
Yes, I have a Windows phone and I have already made several calls through the VoIP application. There are many mobile phones which support the VoIP applications and I just need a Java or an android or more updated operating system. The sound quality is just as good as batter then any call over a GSM network.
We usually use the GSM network in the area to an area call through the mobile phone using a different company’s network. But the VoIP network is so much higher from the GSM network. It always remains hazard free and the sound wave is so low that’s why it remains clear.
Notifications
