Which volume types does windows 2000 professional support and which of this provide fault tolerance?
Volume types for windows 2000 professional
Windows 2000 professional supports basically three types of dynamic volumes:
Simple volumes: This volume which contains disk space from one disk only.
Spanned volumes: This volume contains and shows32 disks show up as one, which are shown in ascending order of their size. When one of the disk fails, the whole array is destroyed. Some data may be recoverable while some is not.
Striped volumes: This is also known as RAID-0.it stores all their data in multiple disks in stripes. This allows improved performance as the disk reads and writes are totally balanced across multiple number of disks. Like spanned volumes, when one of the disk in the array fails, the whole array is destroyed completely. (however some data may be recoverable).
In addition to these disk volumes, Windows 2000 Server also supports:
Mirrored volumes: This is basically known as RAID-1, stores similar copies of their data on 2 or more similar (mirrored). This allows for fault tolerance; if one of the disk fails, the other disk(s) is used as server operational until the server can be shut down for replacement of the disk that has failed.
Striped volumes with parity: This is also known as RAID-5 its functions are similar to striped volumes/RAID-0, except "parity data" which is written out across each of the disks in addition to the data. This allows the data to be "rebuilt" in the event a disk in the array needs replacement.
There are four editions of Microsoft Windows 2000 released, namely: Professional, Server, Advanced Server, and Datacenter Server. It is an operating system produced by Microsoft that can be used on both server and client computers. This operating system supports 3 types of dynamic disk volumes and they are:
Simple volume — a volume with disk space from one disk.
Spanned volumes — where up to 32 disks show up as one, increasing it in size but not enhancing performance. When one disk fails, the array is destroyed. Some data may be recoverable. This corresponds to JBOD and not to RAID-1.
Striped volumes — also known as RAID-0, store all their data across several disks in stripes. This allows better performance because disk reads and writes are balanced across multiple disks. Like spanned volumes, when one disk in the array fails, the entire array is destroyed [some data may be recoverable].
The server family of Windows 2000 supports fault-tolerant volume types and they are:
Mirrored Volumes — the volume contains several disks, and when data is written to one it is also written to the other disks. This means that if one disk fails, the data can be totally recovered from the other disk. Mirrored volumes are also known as RAID-1.
RAID-5 volumes — consist of multiple disks, and it uses block-level striping with parity data distributed across all member disks. Should a disk fail in the array, the parity blocks from the surviving disks are combined mathematically with the data blocks from the surviving disks to reconstruct the data on the failed drive "on-the-fly."
