VOODOO shield error on installation
I have been getting this error while installing VOODOO Shield on my computer.
Error:
The following applications are required before setup can continue: .NET Framework 3.5 Service Pack 1 (3 MB – 232 MB)
Download and install now?
I tried to uninstall the program again and reinstall it. It still gives me the same error message.
How can I install the software without getting this setup error?
Answered By 0 points N/A #155046
Dear Waltere Stone,
After watching your screenshot, I think you should check first that you have any .NET Framework version is installed or not.
I don’t think it’s installed. You better download it and install it first before you install VOODOO into your system.
Try this given link to download it: Microsoft .NET Framework
Try to remember when you are facing any install problem:
  • Disable your Antivirus.
  • Make sure installation source is perfect or active or readable.
  • Download software from trusted web portal.
  • Download with an uninterrupted internet service with a minimum good speed that the download finishes well.
