Albert john
Posted on - 10/01/2011
When i try to start certain applications that require Internet, I get an error message that displays, unable to communicate with the VPN Subsystem and it says check that your network is active. However my network is active but everytime i open this applications i get the same error message.
Thank you for your help.
VPN Client error even though Internet works fine
The disk permission has to be set and the Disk Utility has to be repair for it to work. You'll need to go to the application, click on the Dock and Utilities. This is where you can made changes. Once you have done doing it, to set the Disk Utility it'll definitely will work with VPN.
Turn your computer on then you'll need to go to the main page. In application folder, click twice on Disk Utility, Choose Hard Drive located in the left panel. Look for the default name on the main window then look for "Repair Disk Permission" then open the VPN client once more. This is the steps to fix the problem. But for sure, the steps provided is easy to follow. Hope this help you fix your problem. Please reply back and give us feedback.
