j.mate
40 points
Posted on - 07/08/2011
Good Evening.
I am in search of a solution for an error, that I have received just this morning.
I have attached an image below, in which you are able to view the exact error that appears on my client PC screen.
The necessary VPN sub-system is not available. You can not connect to the remote VPN server.
My client PC is not getting connected to the sub-system, means the VPN server.
The VPN dialer is not working properly. I have tried many times to connect to the server via the VPN Dialer but again and again I receive this error message.
I am looking for a VPN guru who can assist me for this error solution.
If there is anyone out there please respond.
VPN Dialer
JOHNPAUL
VPN Connection Dial up Error
You have not mentioned here, what type of Windows you are using. However, I have one way of resolving it anyway. Please let me know if this has helped you. I have tried it on one of my friend's computer before, but I don’t know if this will work for you.
Let us try to work this out.
In this case, I assume that something needs to be configured in your firewall setting. In a way, like in your computer, Windows comes with a firewall so I suggest you turn off, all that stuff in whatever Windows you are using.
If you are using Windows 7, go to start button of your computer, then go over to the control panel area, then click it. Next, it will show all the settings in your computer, and then look for WINDOWS FIREWALL and then it will get you there.
Turn off or turn on everything, try on or off and then try to connect to your VPN dialer.
I hope this would help you.
