I have installed Hamachi, and I'm having issues with it.
It keeps showing an error saying
Hamachi has lost the connection to the engine everytime I open it.
Restarting both the application and my computer does not fix it.
Can anybody give suggestions on how to resolve this?
VPN connection error with HaMachi
Hi, Check this solution that is given below, and update me is it ok or not? I am waiting for your reply.
First of all, right click on my Computer, find “manage” than open it. After press manage option, double click to open “Services and Application”. After this open “Services” by double click on “Services”. Than from the name list find "Logmein Hamachi", right click on it and find properties. After see the properties, you should stop the “service status” by pressing stop button. Than change the startup type by “Automatic” to “manual". After do this press apply and ok button. And restart your computer.
After star computer again, go to "LogMein Hamachi" service, as you go there last time for change startup type. Aand change again that startup type from “manual” to “automatic”. than start the service by pressing start button. And press apply and ok, after this, hopefully your problem will be solve.
Please update me after apply this, I am waiting.
Thanks and regards.
Adnan
Hamachi is a Virtual Private Network (VPN) and it is a shareware application that is capable of establishing direct links between computers that are behind NAT firewalls without requiring reconfiguration in other words, it establishes a connection over the Internet that emulates the connection that would exist if the computers were connected over LAN. Insome cases Hamachi faces problems and does not open properly and this shown by Hamachi Has lost the connection to the engine ?!!! This happens if the service "LogMeIn Hamachi 2.0 Tunneling Engine" is not started.
1.: Go to "Manage": https://yeri.be/hamachi-failed-to-connect-to-the-engine
2.: Services
3.: Start the tunneling engine auto/manual.
If you keep receiving this error when using Hamachi, try troubleshooting your connection. It can simply be a problem with your internet connection. If your computer is connected to a Wi-Fi router using a cable, disconnect the network cable from the network port then plug it back in. Open your web browser and visit a website then try clicking some links.
Verify that your internet connection is working. If this doesn’t work, disconnect the other end of the cable from the router then plug it back in. If this doesn’t work, restart the router. If the router has a power button, press it to turn it off then unplug it from the power for about twenty (20) seconds.
Press any button on the router to discharge any leftover power or to power cycle. After this, plug the router back to the power and turn it on. Wait until the router is ready then check your connection again. If this doesn’t help, try to uninstall and reinstall. Download the free version of Revo Uninstaller and install.
Once installed, start Revo then select Hamachi among the applications and click “Uninstall.” Follow the normal uninstall process. When you are prompted to restart the computer, click to restart later. When uninstall is complete, click “Scan” to scan your computer for any leftover files and click to delete everything it finds. This removes everything the program created on your computer.
When it is finished, exit Revo then restart the computer. After booting, install Hamachi back. If the problem continues, download a newer version. Download Hamachi on Softonic.com. I’m not sure if this is the latest but this one supports Windows 10.
