VPN error while trying to open GUI
Hi there,
When I want to authenticate to VPN GUI these errors appears all the time. I cannot skip these and also I don’t know how to solve this. Can anyone help me please to fix this error ? What I did wrong ?
Thank you experts !
OpenVPN GUI
Connecting to –shuhaibofficial.blogspot.com_AIRTEL_Server 1 has failed.
OK
Answered By 590495 points N/A #179847
Since there is already a problem with your OpenVPN GUI application, uninstall it and then download a fresh copy of the installer from OpenVPN 2.0.9 GUI 1.0.3 Stable. Download the complete installation package because other links only provides the application only or the executable file only and not the entire package. See image.
Once downloaded, install the package. By default, OpenVPN GUI will be set to start with Windows so configure it if you don’t want to start the program during system startup. Once installed, open notepad and create a configuration file called “xxxx.ovpn” and then save it in “C:Program FilesOpenVPNconfig”. If you are confused on what name or label to give to the configuration file, you may refer to the sample config files located in the folder “sample-config”.
