VPN setup required for my workplace
I want to connect my branch office to my other offices by using VPN. Please help me clearing with the concept as I am an amateur and want to do some research, before I physically implement it.
Once you have all these, then you are ready to do set-up VPN.
The steps are easy to follow, and no confusing instructions can that can caused you headache.
Open Control Panel window.
Go to Network Connections.
Click Create New Connections and Wizard screen will appear.
Select Virtual Private Network and next.
Type the company name and select Public Network.
A dial-up box will appear for initial connection.
Enter the company's IP address to connect to VPN.
Connection Availability should be selected and click next and it has to be as default.
Click Finished and VPN are ready to use.
