VPN Setup Requirement in Philippines
The first thing you should do is to look for the area which has an internet capabilities, don't rent for a location without internet access, especially if that area is too remote. Second would be your application on your VPN. For DATA only
you can avail 64 kbps VPN Connection ideal for the email only. For the voice your requirement is 128 kbps, For the camera
or CCTV application your will need 384. Test your application per site before you get VPN connections from Telco company.
The main site should be twice higher speed than the branch. For example your branch is 128 kbps, your main branch should be double like 265kbps. You can also use IPVPN for your main site just to add security on your system. With regards to pricing the standard 128 kbps VPN would be 2,000 for the 128 kbps plus installation charges for 2,000 per site. The VPN activation is not fast compare to normal DSL because this has to be carefully configure by the telco. unlike the normal DSL which is just easy.
Tony Stevenson.
Notifications
