I extensive use Visual studio but I found out that it does not have built-in WEBDAV support. I am struggling to open a website in Visual Studio. My question is, what should I do so I that vs2008 deployment webdav could be possible?
Is vs2008 deployment webdav possible?
Visual Studio does not have built-in webdav support. However, you can download the patch file which enables visual studio to support webdav. Follow the steps below to install the patch file:
1. Download the patch file and save it on the desktop. After downloading, run the setup file as administrator.
2. Follow the instructions on the screen and install the patch file on your system. Choose the file path where you save visual studio on your system.
3. Now run visual studio and configure the settings for webdav.
This should solve your problem.
