VTS_01 Error when burning ISO file in ImgBurn
I have an ISO image file that I need to burn onto a DVD player but I am getting an error message whenever I attempt to burn it. I use ImgBurn application to burn this ISO file.
Error : ImgBurn
Optimal L1 Data Zone Start LBA: None Found! (VTS_01)
This image has not been mastered correctly for burning onto a double
Layer (OTP Track Path) disc.
None of the cells meet the ‘DVD-Video specification’ criteria for a potential layer break position.
Do you want to continue anyway?
Yes        No        Â
When I tried to click on Yes, it shows that it is doing something but eventually shows the same message. If I select No, it stops burning the file and ejects my disk. If you can share any solution to this problem, I would really appreciate your help. Thank you.
