Vuze error on installing bad image
Can't seem to start or install my vuze software, every time I try it is always giving me this error bad image, can anybody tell me what is this and how to solve this?
Azureus.exe – Bad Image
The application or DLL C:Program FilesMSVCR71.dll is not a valid Windows image. Please check this against your installation diskette.
Best Answer by Glenn Mcgaughey
Answered By 5 points N/A #147157
Dear Zion,
It seems your vuze system files are corrupt, preventing it from launching. Even such a small software such as vuze can stop functioning if something happens to its .dll files (very crucial file format)
You should uninstall vuze by going to Add/Remove Programs in the Control Panel. Then download vuze installer from the following link: Download Vuze 5.1.0.0 at FileHippo.
The fresh installation should fix this issue easily and swiftly. The whole process will only take a few minutes.
Regards.
Answered By 0 points N/A #147158
The error you have encountered occurred because an important OS files is damaged, deleted, misconfigured or corrupted. One common cause of corrupted files is a system that not maintained on a regular basis.
Now that you have an error with.dll, I suggest that you download the DLL-Files Fixer. This software will fix all your registry error and you can download it for free. Fixing your system registry will eventually prevent all your applications from crashing. Follow the link bellow:
https://www.dll-files.com/client/upgrade/
Answered By 590495 points N/A #306323
That error obviously means that the program you are installing is not compatible with your computer. Before installing any application, make sure your computer meets the requirements. Check the system requirements of the application. Unfortunately, with Vuze you won’t find specific system requirements. This means it works on all versions of Microsoft Windows. In this case, try downloading the latest Vuze BitTorrent Client and install it.
You are probably using a very old version that is not compatible with your current operating system. See if this works. Vuze is formerly known as “Azureus.” It is a BitTorrent client that you can use to transfer files using the BitTorrent protocol. It is coded using Java and uses the Azureus Engine.
It was first released at SourceForge.net in June 2003 and is intended to be just an experiment with the Standard Widget Toolkit from Eclipse. But later, it became the most popular BitTorrent client.
