Want to Add Active Directory Custom Attributes.
Asked By 860 points N/A Posted on -
Hello everyone,
I have to Add some Custom Attributes to the Active Directory. I asked my Friends about it, and they were Blanking Out. I want someone to help in Creating Active Directory Custom Attributes.
Answered By 0 points N/A #90059
To make changes in the Active Directory, you have to install an Administrative Tool on the Active Directory. You can follow the steps to install it.
1) Select RUN from the Start button.
2) Open Command Prompt.
3) Type ”regsvr32 schmmgmt.dll” and press Enter.
4) This process will install the Administration Tools.
Now, open Active Directory Schema Tool, Right-Click on the “Attributes” option, and select “Create Attribute.” Click on the “Continue” button.
