Want to add color effects on MS Access
  I am using MS Access 2010, I want to add more color effects on  my database & to that I want to create a color background. So I am using color gradient MS Access but I stuck in it, I can’t understand it’s instruction. Can anyone please help me with this?
Answered By 10 points N/A #166295
Hello Mitchel,
Color Gradient for MS Access
A97GradientFill.zip is function of a database that will instruct you how to use Gradient back grounds for your Access forms with a single function.
Please check this two websites which will clear your concept.
Gradient Tutorial. (You have to download this tutorial)
PC Review.
Hope this will help you.
Thank you and have a good day.
