wyman zeb
10 points
Posted on - 03/10/2013
Hello everyone,
I have to work with multiple forums. Here I need to sign up for all the forums. So I need a system where I can automatically sign up on multiple forums, please help me about this.
Want to automatic sign up on multiple forums
Greetings Wyman Zeb,
The best solution for your problem that I can give is to install Firefox and the addon named AutoFill Forms.
You can set up your information in that addon and once you are about to register on different forums all you have to do is click the button and it will automatically fill the columns.
Check the links below
FireFox Different by design
AutoFill Forms About this Add-on
I'm not entirely sure that this is exactly what you want but it is definitely better then typing out the data each time.
I hope this helps you,
Regards.
