Veer Singh
Posted on - 07/19/2016
Hello guys,
I have a small Business set up. My organization has three offices located in the different parts of the city. I want to establish a Wide Area Network to connect all the offices. So, what would be the Best Dual WAN Router for Small Business?
Want To Buy The Best Dual WAN Router For Small Business?
CISCO is a known brand for making Networking Components. As far as the Router is concerned, I would nominate CISCO RV325 Dual WAN Router that is available for less than $300 online. It is the best model for small business. This Router allows up to Fifty IPSecs with the maximum speed of 100 Mbps and 20 Mbps for SSL VPN. RV325 will be the best unit for you, as you told, your Organization has three offices set up in your city. It weighs just 4.5 Pounds and thus very handy and will be easy to install. You can buy it at Amazon for $234 only. It can straight away create site-to-site VPN.
