lakhansuri
Posted on - 07/29/2016
Hello all,
I’m looking for a Laptop that I can use to edit pictures using Adobe Photoshop CS6. Is there any specialized computer? If yes, then which will be the Best Laptop for Photoshop CS6?
Want to buy the Best Laptop for Photoshop CS6 for editing pictures.
You can buy Lenovo Z70 as it is the best Laptop to run Photoshop CS6, according to me. It has a brilliant 17.3 Inch screen providing high resolution to the users. The resolution can prove to be a big deal for a user like you.
It comes with Intel Core i7 processor with 2.4 GHz processing speed. It comes with NVIDIA GeForce 2GB Graphics Card that can provide better graphics.
16 GB RAM is installed in it that provides a good performance. It comes with 1TB of Storage. Lenovo Z70 will be the best for you.
If you want to install and use Adobe Photoshop CS6, first, check that your computer meets the requirements. Adobe Photoshop CS6 supports Windows XP Service Pack 3 and Windows 7 Service Pack 1. It seems Microsoft Windows Vista is not supported.
It requires Intel Pentium 4 or equivalent AMD Athlon 64 or faster processor, 1 GB RAM, 1 GB free space, 1024 x 768 minimum screen resolution, and 16-bit video card with 512 MB video RAM and OpenGL 2.0 support. Adobe Photoshop CS 5.5 and CS6 also support Microsoft Windows 8.x. If you’ll be installing from a CD or DVD, your computer must have an optical drive.
When using Adobe Photoshop applications, you don’t need a specialized computer for the application. You simply need a supported computer for the application to work.
