Want To Buy An Exhaust Fan For Kitchen Stove
Hey everyone,
The Chimney of my Kitchen has stopped working, and I’m looking for a temporary solution to this problem. I want to purchase an Exhaust Fan for Kitchen Stove. From where should I buy it?
Hey everyone,
I would recommend you to buy a Branded Exhaust Fan, even though the work is temporary. Havells Ventilair DSP will cost you Rs 1,570 in Amazon. You check the availability of this Product in your area. For that, you have to enter the Area Pin Code and see if Amazon supplies it there or not.
It is available on Amazon from 21st March 2014, and many people are still buying it. It does not make any noise when it is working, so it is worth the cost you are paying.
Notifications
