hi
I have created blogger Account now i want to remove this account completely so that no other person can see my Information such as Email and other type of information. I have removed blog which i created.
Now i want to remove blogger account. Please tell me its solution.
My GMail Account should remain only blogger account should be completely closed
I have delete Blog Already. No tell me the method of deleting blog.
Tell me the method of closing blog account.
Regards.
SHAHEEN IQBAL
Want to Close Blog Account
So you successfully deactivated your blog? Am I right? Currently there's no way a user can delete his/her blogger account only ADMINS can do that, but you can try following this steps it will do the same thing (so that search engines would not end up displaying your information) .
Edit your Personal Information and remove all the things that are stored there
Change your username into another one so that your old username will be available to others
I hope this is helpful 🙂 .
John
SPaul
Blogger does not have a way to delete the profile information and other details. That is if you delete your blog still the profile and any comments left by you will remain on the backup system.
So you can use Edit your profile to remove your personal details and fill with false information. You already deleted the blog so changing your username will also disconnect you from the blog.
If you are not interested with your Gmail account you can delete your email address forever and no one will access your profile. This is a major drawback with blog accounts and I hope it will be resolved soon by Google.
