I want to connect fitz 6544 to my Home PC from work but I can’t install any software from there.
I am using the router, which have set up port forwarding. When I try to connect through my home LAN from another PC then I get the following error message. Any help would be appreciated. Thanks.
Pc3 ( 192.168.1.205)
Error: Framebugger update rectangle too large: 0×0 at (63972,36733)
Java Applet Window
Want to connect fitz 6544 to my Home PC
You can try doing this solution.
First, connect using Javavnc. Choose the options button in the VNC authentication screen. Afterwards, you should get to the "options button update". When you get there choose "disable" or "ignore". It will make Javavnc fully functional. It is a work around and it has helped othere solve this problem.
Hi.
This problem occurs with release candidate or unstable release for VNC server. Try to go back to an stable release and. JavaVNC will not fix anything. For best results use TightVNC or maybe EchoVNC. Workaround is to choosing options from authentication screen and ignore or disable cursor shape updates. With this workaround JavaVNC will be functional.
Queen Norman
