I am a new Win32 Programmer and I have a university book. I want to write that code and execute my first program please tell me how can I do this.
I want to create a Win32 Application.
Please tell me it's complete detail.
James20
5 points
Want to create New Win 32 Application?
How to create a Win32 Application
Follow the following steps to create a WIN32 GUI based application project:
Select FILE from the main menu
Select NEW
The following window will appear:
In the above window, you need to do the following 5 things
select Win32 Application in the above window
write your project name on the upper left side of the window
select “CREATE NEW WORK SPACE” radio button
check Win32 check box
click “OK”
After performing the 5 tasks above, the following window will appear:
In this window you need to do the following
Select “AN EMPTY PROJECT” option.
Click “FINISH”
After performing the above 2 tasks, the following window will be appear:
You just need to click “OK” in the above window
After pressing “OK” in the above window, the following window will be appear:
Your project has been created
How to add a new file in your project
To add an already created file,
Click on FILE
Click OPEN
Select the file to be added
To add a new file in your project, do the following steps:
Click on FILE
Click NEW
Select C++ Source File option
Select project in which you want to add the file
Enter file name in the FILE NAME text area
Browse the location in which you want to save your file
Click “OK”
After performing the tasks above, your new file will be added into your project.
