Want to create random disk id
Hello, I am using windows 8 home premium on my laptop. I want to create random disk id without using any downloadable software. I want to create it using windows 8. Please tell me how doing it or tell me the name of the tool. Please reply me as soon as possible. Regards.
Answered By 0 points N/A #164787
Hi Shannon Wheelock,  here are the steps on how to create a random disk I.D., First, “disconnect” all plug – ins then “reboot” and “re – install” it again. If it failed, try again.  Also, if the setup is unsuccessful to the partition, just close the set – up tab.  Second, go to “initial setup screen”.  Third, click “repair,” and go to advance tools and command line.  Fourth, go to “disk part”.  Put “list disk”, identify your “SSD disk #”.  Fifth, key in choose disk (n) where (n) is the SSD number.  Sixth, key in “clean”.  Seventh, key in “do partition primary”.  Key in “active”. Format fs=ntfs quick.  Eighth, key in “assign”.  Last, type exit twice.
