Hello expert, I need a help. I want to create some flow charts.
Can I create charts using Microsoft access?
If any specific application other than Microsoft access please suggest and provide the download link and other instructions.
Thank you.
Want to create some flow charts
Hi Christopher,
If you wanted to create stunning, impressive and professional flow charts, I would recommend SmartDraw.
I have been personally using it.
It is user friendly and anyone could use it immediately like a pro.
It is not limited to creating flow charts but you can also create diagrams, Gantt charts, floor plans, organizational charts and a lot more. A professional quality of charts will be created with just a click of a few buttons.
You can download the free trial .
Good luck and hope you find this amazing as I do.
Hi Christopher,
Microsoft words are the simple way to create flow charts.
To create a flowchart using Microsoft word,
Go to Insert > SmartArt under the illustrations tab and then choose the SmartArt Graphic you need from the list.
You can apply colors, different themes to you flowchart to make it attractive.
Using Microsoft word will be most best .But access can't. MS words can.
You can only import the flow chart file(s) that had been saved.
In Access click the external data , click saved on the tab-menu.
Then click on saved imports.
Then the grid key of browse will pop up browse the file you want to import .
