Want custom icon packs for firefox
I want to change the default Firefox icons. Will it be possible to do? If yes then tell me where can I find custom icon packs for Mozilla Firefox.
Hello John,
You can change default Firefox icons. Just go to the properties of Firefox icon.Â
Click on Change Icon button located at "Shortcut" Tab
Now Click on Browse Button and give the path or paste the followingÂ
%SystemRoot%system32SHELL32.dll
You can see other icons.
For further information reply.
Hi there user:
That was quite easy to do. By doing this, you can as well refresh you explorer. Un-install Firefox, and install it again. Or download the new version, just in case there is an available new version to download. After the install, it will return into its default state.
Thank you for dropping via techyv.comÂ
Yes, you can change your Mozilla Firefox browser icon easily. You can download icons from the web. These will be just an extension which is needed to add to your Firefox.
You also can go to Start menu >> All programs >> Right click on Firefox shortcut and select properties >> Select change icon. Then an icon changing window will open. There, you can browse and choose your favorite icon.
You also can use especial converting software to create Firefox icon extensions (*.ico). You can change your favorite images into a *.ico file and install it in your Firefox browser.
