Want dbf addin for excel 2010
I have been using Dbase as my backend of my finance application now I want dbf add-on for excel 2010 which can able to dbf files in excel and make my work easier kindly suggest
Hello Skylabreonna,
I see that you are seeking an add-on that will open dbf files in Microsoft Office Excel 2010. There is no need for an add-on to do this kind of job. There are two ways to open a dbf file in Excel which are mentioned here:
Hope that this solves your problem.
P Vhilary
Try installing XTtools pro. XTools Pro is an extension for ArcGIS. There are many features of this software that will help you not just in your problem as of the moment. One feature that you can use to address your problem is "Export Table/Data to MS Excel". This is a new option to export fields.
