Want to download cad xref viewer software free and supported linux version
Hello expert, I am an Architecture and I am using AutoCAD. I want to add cad xref viewer into my ubuntu 12.10 version OS. So I want to download cad xref viewer software free and supported linux version. So please give me the links to download it free. Thanks.
Best Answer by Bernard L Jefferson
Answered By 0 points N/A #164238
It was difficult to search that software but I searched some xref software which will be helpful to make you professional. You can download auto cad xref software which will be fast, powerful and compatible CAD software. You will be able to design any thing with advanced and skillful features. You have to click on the following link to download auti cad xref software. I hope it will solve your problem.
http://www.download32.com/autocad-xref-freeware_2.html
http://xref.winsite.com/
Answered By 65 points N/A #164239
Hi Virginia,
An X-ref is an 'external reference' to another AutoCAD drawing file. One file can reference many other files and display them as if they were one.
Mini CAD Viewer 3.0.1, VariCAD Viewer 2013 for Linux 1.03, VariCAD Viewer 2010 for Linux 3.02, and VariCAD Viewer 2011 for Linux 1.08 are downloadable via this page.
It cost nothing to download them.
