Want to download cisco script generator
There are many types of software on this section. It is one kind of server management software. I recommend you to download the following software:
Cisco ICM Internet Script Editor
I like these softwares very much.
I also attach a tutorial as pdf for your ease.
I would recommend you to download the Jabber Config Generator. This is the easiest to use since it gives you what configuration to use. You just simply copy and paste them. It is most recommended by the Cisco communtity and even gathered a perfect of 5 star ratings. Here is the link to download it: Â https://supportforums.cisco.com/t5/collaboration-voice-and-video/jabber-config-file-generator/ta-p/3112597
If you want more choices, there is always the Config File Generator (developed by PmGSoft Tools) although it's not that easy to use and even gathered a low rating. Here is the link to download it :Â http://configgen.codeplex.com/
