Want to download dns tester for my Zorin OS
Hi.
I am using Zorin 6.0 OS on my laptop. I have to check dns in my computer. So I want to download dns tester soft for my Zorin. Please provide me some links to download it. The software should be without .exe file one, because .exe files don’t support to linux.
Best Answer by Michael B Rodgers
Answered By 0 points N/A #164779
Hello Shannon,
As you mentioned, you are using the Zorin 6.0 Operating System which is developed based on UBUNTU 12.04. Now you want to test your DNS through a DNS testing software which supports your OS. You can do it by using Dual DHCP DNS Server which is an open source product that supports both Windows/Linux.You can use this as a DNS or DHCP or both. You can also check your DNS in http://www.dnssy.com/
Answered By 45 points N/A #164778
Hello Shannon,
It seems you are having a problem downloading DNS tester for your Zorin operating system. Users who already have Zorin OS 6 or 6.1 Core/Ultimate installed can update their system using the Update Manager to avail of the aforementioned updates and improvements in 6.2, except for Zorin Menu. A clear version of Zorin OS 6.2 can solve your problem for good and you can download any DNS tester for your OS.
I hope this helps.
