Hello expert, I am using windows 8 beta version on my computer. My friend needs a software about erasing logo in softwares and folders. So I want to download logo eraser free. Please suggest me some links to download it easily. Thanks. Â Â
Want to download logo eraser free
I am sure your friend is a little programmer as a programmer can only make changes to the windows files and it require programming skills. However, we do not advice doing this. Each software has their own manufacturer and their logo is their trademark. Also, I couldn't find any logo eraser software that will fit your needs. However, if you want to go along with this, maybe you can try to search on Google about some tool that will help you modify your system files or how your Windows will look like by modifying their resources.
