Hey all,
I am looking for an Application that I can download and install to my PC. I want to add Bulk Users in the Active Directory. Which Tool should I download to Create Bulk Users in Active Directory?
Want to download a Tool to Create Bulk Users in Active Directory
You can go for Active Directory User Creation Tool, Version 1.2. As every System Administrator encounters this problem, this Tool proves to be very supportive of them. It comes without any bug. The previous versions had a problem with them. The application generated wrong Username and UPN in the CSV Files. It comes with pre-included XML Files that can set Default values for Fields. You can add Bulk Users by clicking on File, and then select CSV Mode. After that, you can import all the users present in the CSV. Click on the URL to download the Program.
https://gallery.technet.microsoft.com/scriptcenter/New-User-Creation-tool-14fa73cd.
