Hello everyone,
I am using a MacBook. Here I have featured about remote control manager MacBook but it is disabled. Please help me to enable it, How can I do this? Reply as soon as possible.
Thanks in advance.
Want to enable remote control manager Macbook
Greetings Madison,
In order to enable your Remote Control Manager you need to go to System Preferences under Internet and Wireless find Option Sharing.
In Sharing tab find Remote Management
Check this image:
Click on the Remote Management: OFF to enable it. In the below area if you want all users to be able to remote control Your MacBook select All Users otherwise you can define and add your own users by checking Only these Users and pressing the + icon to add.
I hope this helps you,
Regards.
