I am making several presentations on agriculture related topics and I want to add some gif images which indicate latest technologies of modern agriculture. Please tell me how to find images gif latest of this topic or easy software to create gif images with tutorial because i have many jpeg photos. Please help me. Thanks.
Want to find images gif latest on Agriculture.
Hello Harnandez King, You can search gif images on Google Search, however you put some parameters on your search. Type in keywords related to your topic such as "Modern Agriculture" and add ".gif" at the end. In the search tools adjust the time frame for latest images. If you want to create gif images yourself, you can either do this online at: http://picasion.com/ All you have to do is upload the images you like and the website will make a gif. You can also design a gif image yourself by using a professional software like Adobe or CorelDraw, you will get tutorials with the software and you can find help on how to use these software on the internet.
Halo
There are many ways to create GIF file from JPEG file. I am writing how to create GIF file from Microsoft paint.
Step 1 : Open Microsoft paint from your start menu.
Step 2 : Open a picture. you can add a picture by clicking on past>past from (left sight)
Step 3 : Click file>save as Now click on GIF
Created your JPEG file to GIF file !
Go to Google and then click on Image mode. Type there your keyword and search…. You will able to get any kinds of picture there !
REGARDS
Washington Michael
There are so many latest technology images related to agriculture in JPG but if you want GIF images you should search from the Google with easy steps.
1- Write in the Google search bar ‘’latest technology images related to agriculture.gif’’
2- Click on the following links which show the better images in GIF
Now I would recommend you software which can create GIF images.
• Software: SSuite Office – Gif Animator
Just load your images into the list, and press create. That is how easy it is to use. Supports jpg, jpeg, and bmp images.
