Want to find iPhone Folders alternative for win7 64 bit
I am wondering if i can have the Iphone Folders alternative for win7 64 bit.
I used this software in my xp laptop and i am familiar with the user interface, now need a similar application to use in win7 64 bit.
Thanks in advance
Answered By 0 points N/A #169299
The iphone folder can be found for all operating systems. You just have to find the right iphone folder setup for your specific operating system be it 32 bit, 64 bit or 84 bit. In the setup, there are specification for a particular setup such as for windows xp, windows 7 and so on. I have found a setup download from http://iphonefolders.com/ but it states that there is no support for 64 bit because the setup can’t be forced to execute in windows 7 64 bit. Just check out other websites for the setup.
Thank you.
