Want the flag 3d screensaver of csa
Asked By 110 points N/A Posted on -
I want to download the flag 3d screensaver of csa. I am looking for the free one. Where can I find it? Please give me the link to get the flag 3d screensaver of csa for free. Can I use it as my desktop screensaver? I use windows 7.
Best Answer by Niley Samilene
Answered By 10 points N/A #144580
Hey David Parfit
I see that you want to download a 3d screensaver of CSA flag for free, then you should checkout the link below:
 http://www.geliosoft.com/3d-flag-screensavers/confederate-flags-screensavers.html
and if you want to download screensavers of different flags then you should visit the following link:
http://www.geliosoft.com/3d-flag-screensavers/index.html
Good Luck with the 3d screensaver!!!
Answered By 0 points N/A #144581
Hello David Parfit,
I read your topic where you want to download the flag 3d screensaver of csa for free.
There is a link where you can find your free the flag 3d screensaver of csa.
Link: http://softwaretopic.informer.com/flag-3d-screensaver-csa/
Yes! You can use it as your desktop screensaver though you are using windows 7.
