Want to install Adobe Flex 4 Paint. Can anyone help me?
Hi Experts,
I own MacBook Pro 2.6 GHz and want to install Adobe Flex 4 Paint. I have downloaded it from a website unzipped it. Now there are different directories in the unzipped folder. I don’t understand what to do next for installation. Please help me how should I install. Can anyone tell me that does Flex 4 have any compatibility issue with Mac?
Answered By 240 points N/A #136083
Wassup Avah,
I believe I can be able to help you solve your problem. When you download and unzip your program, there are different directories that will appear and one of them is the one that contains the installer.
Adobe Flex 4.5 Fundamentals
You will need to look for a folder with the .exe extension such as 'Adobe Flex 4 paint.exe' from the list of the directories, this should be the installer and after extracting it to the specific folder you want, you can then click on it to run and install it.
Follow the instructions to install it properly and ensure you add all files and entries in the registry then afterwards you can restart your computer.
Files to registry
You can then click on the program to run it and it should be working well and normally.
I hope this solves your query.
