Bersh Roman
30 points
Posted on - 01/24/2013
I am interested to install wood sign Photoshop brushes in my MacBook running Mac OS X 10.5.6.
Help me to find out the high resolution wood sign brushes.
I shall be thankful if anyone writes step by step process (with images help) of how to install them.
Want to install wood Sign brushes in Photoshop for Mac
Hello Bersh Roman,
I have found a website from where you can download Photoshop Wood brush pack, it has 19 different styles of wood brushes,
Please visit the site as you will find other material brushes as well.
It supports Adobe Photoshop CS3 version, here is a link to the website:
Hi Bersh,
To install your favorite wood sign Photoshop brushes you first need to download your desired brush from the site
Once you have downloaded your brush now you need to install them and hence do the following as you are running Mac.
Navigate to the following folder:-
/Users/{username}/Library/Application Support/Adobe/Adobe Photoshop CS5/Presets/Brushes.
And paste your downloaded brush in this folder.
It’s as simple as that. Now you go inside Photoshop and go to brush tool and click on load new brushes.
Hope this helps.
Thanks
Baker
Hello Roman,
You can download many wood brushes for your Mac book in online.
You can find those by searching in Google.
If you need high resolution wood sign brushes then you can visit below link.
I think you can download many brushes and use them easily from this link.
You can find 100 beautiful wood sign brushes from this link.
