Want java epub reader for sony ericsson c905
I have a sony ericsson c905 and I want a java epub reader for my handset. Tell me where to get a java epub reader for my phone.
If you want to install an Epub reader for your mobile phone, here are some of the Java-based Epub readers I was able to find:
Feel free to try the Epub applications listed above and see if one of them will work for you.
Hi Olivia,
As you are using Sony Erricson c905 which is java supported mobile phone you can use any of the below links to download the java epub reader. Sometime it may crash your mobile device when you install this software, so please take a back up of your data before you install this software.
Please follow the link to download the software.
Andrew Shavaka
