Want to know 2 things about japanese bookshelf speakers
I am planning to purchase Japanese bookshelf speakers.
I have 2 questions regarding it.
1. Which model should I purchase?
2. Can I use Japanese bookshelf speakers without wires?
Waiting for your answers.
Best Answer by Kumay Edwards
Answered By 0 points N/A #145129
Hi Suzanne,
Your decision for buying Japanese bookshelf speakers is really great.
There are many varieties for bookshelf speakers from Sony. You can get any of the Wireless models.
Sony AIR-SA10 is one of these wireless speaker models. You can use it in many rooms.
I think you can try it.
Answered By 5 points N/A #145130
Hi there,
Paradigm Shift Series A2 Powered Bookshelf Speaker are gaining popularity now a days with remarkable speed!
They are reviewed and given 5 stars feedback at amazon.com and many known technology forums.
About your second answer, if you want to use bookshelf speaker wirelessly, it depends on model, if you purchase a bookshelf model having wireless option then obviously you can use it wirelessly!
Or you can use some wireless setups like A2 wireless setup and  ZiSound T6, these setups require routers, receivers ad amplifiers for sending and receiving of signals!
Hope that helps!!
