Want to know about the Crystal Reports 10 Windows 7 compatibility.
Hey all,
I want to know if Crystal Report 10 is compatible with Windows 7. If it is not compatible, then which version of the Crystal Reports will be compatible with it? I need someone to tell me about the Crystal Reports 10 Windows 7 compatibility.
Answered By 0 points N/A #83489
To be honest, Crystal Report 10 is not at all compatible with Windows 7. It is an old version that people use very rarely. You can check the following URL to have a look at the compatibility of all the versions.
https://archive.sap.com/content-not-migrated.
No version up to CR XI R2 SP6 is compatible with Windows 7. The versions above this have no compatibility issues with Windows 7.
You can upgrade to VS 2010 and Crystal report for VS 2010 along with the .NET Components.
