Want to know about drive activity for XP
Hello everyone, I am using Windows XP. I want a software that tells me the  drive activity for XP, because sometimes my PC is slow in idle mode. Please give some strong comment.
Hello, Stephen! I would like to say that you can take "Advanced System Care-Pro". It's totally preforming on your PC's system. Junk files removal, smoothing performance by removing others issues. In fact, I want to say that you check your PC's system nay time when you need it. You can get it both FREE and Pro version. Have a nice time!
Hi Stephen R Gate,
Dear you should use some monitoring tool in this regard. Monitoring tool will show you all the activities of your system.
It will show you about the usage of hard disk, RAM, CPU and other components.
I will tell you to use software for this action. I have searched a better thing for you.
You should use Drive GLEAM software. It will show you all the activities of your computer. Like hard disk, CPU and RAM usage. You can download this utility from this link.
http://www.softpedia.com/get/System/Hard-Disk-Utils/DriveGLEAM.shtml
I hope this tool will better for you.
