I am using the OS Windows XP. I want a good 3D Modeling Software like EZ Architect 4.
Can anyone provide me with any good reference to download it?
I also need to know the PC configuration for this software.
Want to Know the PC configuration for EZ Architect 4
Dear user,
EZÂ Architect is no doubt the most popular and widely used software, highly recommended.
It is an accurate home design software. It can be used on Windows XP, Windows 7, Windows 8 and Windows Vista.
It can also be used on a Mac has Intel dual-boot processor. Its new version of 2010 contains many new features.
You can download it for free from http://www.place77.com/.
Hope this will help you.
Thank you.
If you want or need to use Ez-Architect, try the demo version: Ez-Architect 9.01 on Softpedia or from the official website: Ez-Architect 9. Before downloading, check that your computer meets the requirements. This demo version of Ez-Architect supports Windows XP, Windows Vista, Windows 7, Windows 8.x, and Windows 10. It requires Intel Pentium 2 or faster processor, 256 MB RAM, and 50 MB free space.
The following are the limitations of the demo version:
- Nag screen.
- Print, save, and export functions are disabled.
The full version costs $5. Ez-Architect is a floor plan and home design software. It allows any user to produce professional looking home designs, floor plans, architectural drawings, and building plans easily in just few minutes. It is a drawing program that you can use to do any of the following:
- Kitchen design
- Data flow diagrams
- Flow charts
- Bathroom design
- Network diagrams
- Office layout
- Home layout
- Electrical wiring diagram
- Stage plans
- Interior design
- Clothing design
- Maps
